Aug 15th, 2024, 6:23pm
breakdown voltage (Read 2053 times)
aamar
breakdown voltage
Aug 31st, 2005, 5:57am
Dear Sirs,
I am using a device model (subckt)  which is including a MOS transistor, in my simulations I have to reach a voltages of about 30V on the gate source of the transistors, I receive a warning from Spectre telling that Vgs has exceeded the breakdown voltage of Vbox=30V.
only warning, no errors and at the end I get results for the simulation.
Are these simulation results true or not?
At the same time what is the effect of reaching these voltages on both DC and transient behav. of the transistor?
Is there any other technologies which can hold these 30V other than the High voltage models ?, it doesn't matter the process at the moment, bcz I am just simulating.
Thanks in advance.
aamar
Re: breakdown voltage
Reply #1 - Aug 31st, 2005, 12:37pm
You may be getting a default value for Vbox; the documentation says
224     vbox=1e9*tox V    Oxide breakdown voltage.
so if you have a tox of 30nm, you'd get Vbox=30.  You should look in your model card to see if there is a value specified for Vbox, indicating that someone decided they had enough information to specify such a quantity.
If you're just simulating, you can (a) ignore the warning, since it's just a warning, or (b) add Vbox=10000 to the .model card.
-Geoffrey
