Jul 24th, 2024, 2:27am
programming a decoder in AHDL,Verilog-A (Read 5938 times)
vivkr
Sep 01st, 2005, 2:16am
I am trying to create a macromodel for a decoder with 12 bits of control and 4096 outputs.
I was trying to create this using AHDL or Verilog-A but run into trouble with indexing of the signal array. It seems that I can only specify a numeric constant for the signal array. However, this seems to defeat the purpose of using indexed arrays of signals.
I would just like to be able to assert 1 out of the 4096 signals high based on the result of a calculation, and hence my array index element is not constant but a variable.
Has anyone tried such a thing in AHDL or Verilog-A?
Re: programming a decoder in AHDL,Verilog-A
Reply #1 - Sep 1st, 2005, 8:45am
It's a little clunky, but this works for me:
`include "discipline.h"
module dcdr(in,out);
  inout in;
  inout [0:3] out;
  electrical in;
  electrical [0:3] out;
  real vin;
  integer indx;
  genvar j;
  analog begin
    vin = V(in);
    if (vin < 1) indx = 0;
    else if (vin < 2) indx = 1;
    else if (vin < 3) indx = 2;
    else indx = 3;
    for (j=0; j<3; j=j+1) V(out[j]) <+ 0.0;
`ifdef ORIGINAL
    V(out[indx]) <+ 1.0;
`else
    for (j=0; j<3; j=j+1)  if (j==indx) V(out[j]) <+ 1.0;
`endif
