When you're referencing this file, are you including just particular named sections from the file, or are you including it as a whole (without giving section name)? I think the latter would cause such an error - if a file contains a library definition, you have to include it with a section name to pick out which section you want to pull out of the library.
Are you referencing the file via a MODELPATHS statement in your hdl.var or via the model library (I think that's what it's called) from the AMS pulldown in the hierarchy editor?
