May 8th, 2024, 10:57am
Dropout Voltage Simulation (Read 5838 times)
Raj
India
Sep 04th, 2005, 10:35pm
Hello ,
          Can anybody tell me How to do Dropout Voltage Simulation for a CMOS Voltage Regulator which converts 1.2V reference from BandGap to 1.8V output. Supply voltage is 3.3V. Any suggestion on test-setup for this simulation is greatly appreciated.
Packiaraj.V.
View Profile packi_raj   IP Logged
Re: Dropout Voltage Simulation
Reply #1 - Sep 28th, 2005, 5:23am
Raj,
Would you please give the purpose of the simulation? Do you want to run transient simulation or AC simulation?
Yawei
Reply #2 - Sep 29th, 2005, 5:40am
Raj,
   Since you don't mention whether you are working on
a linear regulator or a switching regulator, let's assume
that you are interested in an LDO. In that case, just
use your standard testbench and do a dc sweep of
the input voltage and and look for the voltage when
the regulator goes out of regulation. At some point
the output voltage will change as the input voltage
changes, that is, voltage where the regulator goes
out of regulation. The difference between the input
voltage and the out voltage as the regulator goes
out of regulation is the Droput Voltage.
Raj
India
Reply #3 - Oct 5th, 2005, 7:22am
Hi Sheldon,
                  It is LDO regulator that employs an OPAMP and PMOS pass device. The PMOS pass device is connected to the output of OPAMP. Its source is connected to VDD and to the drain there are two resistors in series. The -ve OPAMP input is from the bandgap i.e., 1.2 Volt. +ve input is drawn from the middle point of two resistors connected at the drain of PMOS pass device.
                   When I swept the supply voltage VDD , the output voltage whose nominal value should be 1.8 Volt varies drastically. The output voltage also ramps when it is supposed to stay at 1.8 Volt (Line Regulation).
Any problem in circuit or way i understand?
Thanks in advance,
Packiaraj.V.
Reply #4 - Oct 5th, 2005, 6:51pm
Raj,
What is the voltage range did you swept? Have you checked the voltage at the gate of the transistor gate?
Yawei
