Aug 15th, 2024, 7:36am
how to (Read 7177 times)
microant
China,SH
how to
Sep 07th, 2005, 1:13am
Hi All
   i meet a problem with Hspice. i want to simulate a circuit with TRAN analysis and change the simulation temperature along with time.
  is it possible to implement in Hspice or there is another way to achieve the same result? is anyone give me some suggestion. ???
thanks and best regards
microant
Paul
Switzerland
Re: how to
Reply #1 - Sep 7th, 2005, 12:59pm
I'm not sure, but it seems to me temperature cannot be changed during a transient simulation. Maybe this is related to the fact that it is an input parameter to the device models.
Paul
Re: how to
Reply #2 - Sep 7th, 2005, 4:08pm
I don't know whether this is possible in hspice. Currently it can't be done in spectre, but there was discussion about doing this for devices which already supported self-heating - that said, it's not been done yet AFAIK.
microant
China,SH
Re: how to
Reply #3 - Sep 7th, 2005, 5:22pm
Hi Andrew and Paul
   Thanks for your response!
   i didn't understand what you mean the following
best regard
microant
Re: how to
Reply #4 - Sep 7th, 2005, 10:14pm
AFAIK = "As Far As I Know"
Sorry for me using unfamiliar abbreviations. Lazy on my part.
Re: how to
Reply #5 - Sep 8th, 2005, 8:39am
If the device supports self-heating, one could use a time-dependent voltage source to set the temperature from the simulation time.  The device temperature in Kelvin is the same as the "voltage" of the thermal terminal.  However, if you set the temperature in this manner, the device won't exhibit any *self*-heating; the voltage source is a perfect heat sink.
microant
China,SH
Re: how to
Reply #6 - Sep 8th, 2005, 5:16pm
Hi Geoffrey_Coram
   Thanks for your help! but i don't understand what means about 'the device supports self-heating', Could you explain in detail or illustrate? thanks.
best regards
microant
Re: how to
Reply #7 - Sep 9th, 2005, 4:33am
The advanced bipolar transistors (mextram, hicum, vbic) support self-heating, by which the power dissipated in the device makes it warmer, which changes parameters such as the saturation current.
I think some high voltage MOS models in commercial simulators also support self-heating.  And some implementations of BSIM3 have added it, as well.
But the point is, the model equations are already set up to change the parameters during the simulation, not just a dc temp or parameter sweep, but also a transient analysis.
Jaw
Re: how to
Reply #8 - Oct 3rd, 2005, 6:16pm
Is it really necessary to include the temperature change during transient simulation? For most of circuits, I guess the period of transient simulation is much shorter compared to the temperature varying period. It should be just enough to simulate a set of transient simulation in different corner temperatures.
Unless you need to simulate a circuit for a really long time ...
Re: how to
Reply #9 - Oct 3rd, 2005, 6:37pm
Jaw,
  Some circuits are sensitive to thermal effects, for example, the input
of a comparator. If one device is on and one device is off, then the
power and the temperature of the devices are different. When the
inputs return to the balanced state, there is now a time-dependent
offset voltage due to the difference in the device temperatures. This
can degrade the comparator's sensitivity.
The issue is rela
Re: how to
Reply #10 - Oct 3rd, 2005, 6:42pm
Jaw,
 Sorry about that Mozilla and I had a disagreement:-)
 The problem is fairly common in real designs in particular
bipolar designs and many times circuits have specifications
for transient overdrive recovery.
