I'm working with a BJT (doesn't really matter what model), and trying to understand the value of gm.
According to first-order theory, gm = Ic/Vt. gm is really defined as the partial derivative of Ic with respect to Vb.
Now, if I do a sweep of the base voltage, I can plot Ic/Vt and derivative(Ic) on the same graph, but they don't agree for high base voltage (off by a factor of 2). Ic/Vt does match the "gm" reported by the device fairly well. I've tried turning off self-heating, and I've checked that there isn't much base current (Vbe - Ib * Rb hardly differs from Vbe) and there also isn't much avalanche current.
What else needs to be considered?
