May 17th, 2024, 9:36pm
Binary representation in verilogA (Read 668 times)
parthsv
Oct 11th, 2005, 4:29pm
Hi All,
 I am currently working on digital calibration of ADC. I am presently modelling the algorithm(VerilogA)  for which I need a 7b counter. Is it possible to have a binary counter  like in Verilog (As I do not want to spend time on modelling the counter) say for eg:
 Counter <= Counter + 1'b0; (syntax may not be exact)
Thanks in Advance,
Partha
jbdavid
Re: Binary representation in verilogA
Reply #1 - Oct 12th, 2005, 12:53am
you can't have binary numbers.. but you can have integer variables and there are bitwise operators for them..
do you thing this would work for you?
integer counter
analog begin
  @(cross(V(clk,clkb),+1,ttol,vtol) begin
      counter = (counter +1)%(1<<7);
of course if you'd use Verilog-AMS you could
use your normal Verilog construct for the counter..
jbdavid
