Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 15
th
, 2024, 3:29pm
Home
Help
Search
Login
Register
PM to admin
Design
RF Design
› Drawing cross coupled pair
Previous topic
Next topic
Drawing cross coupled pair (Read 3574 times)
Derek
Guest
Oct 12
th
, 2005, 1:04am
Hi All
I drawing some cross coupled mosfets using cadence schematic composer. Looking at some schematics drawn before, the wires could be drawn at diagonal degrees. I tried toggling with the options, but all my wires are still in orthogonal mode. Know that this is no of grave importance, just curious.Does anyone know where to tweak to draw wire diagonally? Thanks.
IP Logged
Re: Drawing cross coupled pair
Reply #1 -
Oct 12
th
, 2005, 1:35am
Derek,
Did you try the F3 key while routing a wire? The default for Draw Mode
is route, try setting it to the diagonal option.
IP Logged
Derek
Guest
Reply #2 -
Oct 12
th
, 2005, 7:34pm
Hi Sheldon
Thanks.. yr suggestion works like a charm.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
»» RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
