If you use noisetype=modulated, you can plot the AM and PM components of the noise. However, I don't think there's anything to allow you to see the individual noise contributors with AM and PM components. I assume this could be done, since the data to compute this is present, but it's not something that is currently available (unless I've missed it).
You should contact customer support via your usual channel - perhaps this could be an enhancement request.
