Aug 19th, 2024, 12:26pm
Device fmax and ft (Read 5001 times)
crhu
I come, I see, and I
go
Device fmax and ft
Oct 25th, 2005, 5:21pm
Hi, forum,
I am doing some device characterization, and I am really puzzled by the results I got for fmax and ft
fmax ~ the freq. @ which unity unilaterizated max power gain occurs
ft ~ the freq. @ which unity current gain occurs
Based on the equation:
fmax = 1/2*sqrt(rds/Rg)*ft,
for MOSFET,
rds = 1/gds (~10k - 100k),
Rg = Rpoly + Rchannel=1/3*W/L*Rsh + 1/5*1/gm (for long device) (~ 10 - 1k),
fmax should be always larger than ft for MOSFET.  However, the results I got always show that ft>fmax.
Thanks.
-ch
Re: Device fmax and ft
Reply #1 - Nov 14th, 2005, 8:14am
I've always seen fmax >= ft.  Are you sure you're measuring ft correctly?  In some cases, the unity current gain point is subject to strange effects, and one should really use a linear extrapolation from the 3dB point (where the gain has dropped 3dB from the dc value).
