Aug 19th, 2024, 12:19pm
1/f noise versus  process (Read 3528 times)
cktman
Dec 13th, 2005, 11:02am
How does 1/f noise scale in smaller-geometry processes? Assume that I have a current-mirror that has constant area for 0.35um, 0.18um processes, etc. How would you expect the 1/f componet of the output current to scale?
Terence
CAD Lab.
Taiwan, R.O.C.
Re: 1/f noise versus  process
Reply #1 - Dec 14th, 2005, 2:42am
My opinion is the following.
The number of traps in GOX will be reduced with the thinner GOX. Therefore, the 1/f noise should be reduced with process scaling down.
You may read this paper, " Future perspective and scaling down roadmap of RF CMOS, "  Symposium of VLSI Circuits, 1999.
Reply #2 - Dec 15th, 2005, 8:46am
I would think that the effect of the (smaller number of) traps would be larger in a smaller-geometry process.  Also, 1/f noise can average out for large devices: one trap is occupied, but another isn't, and the effects cancel.
Probably also the trap density is a function of the maturity of the process.  In fact, the developers of the HiSIM mosfet model claim that 1/f noise needs no fitting parameters for a mature process!
S. Matsumoto et al,  "1/f noise characteristics in 100nm-MOSFETs and its modeling for circuit simulation,"  IEICE Trans. Electron., vol. E88-C, pp. 247 254, 2005.
