Aug 18th, 2024, 7:03pm
ring vco (Read 4187 times)
vijay
ring vco
Oct 26th, 2005, 6:16am
Hi friends,
could anyone guide me in getting a link to get the exact relation of frequency with current in a ring symmetric load ring vco.Using paper from maneatis, as one of guidance.
Thanks in advance.
keble
Re: ring vco
Reply #1 - Oct 30th, 2005, 12:45pm
Hi Vijay, I posted a reply but it disappeared! Finger trouble I guess.
Maneatis's 1996 paper gives F=sqrt(2*k*Id)/(n*Ceff)
where:
k= the beta (W/L*K') of one of the PMOS symmetric loads
Id = half the buffer current
n = number of stages in the ring
Ceff = total capacitance that gets charged/discharged per stage
Is this what you meant? It's quite straightforward to derive the equation
Rob
vijay
Re: ring vco
Reply #2 - Nov 2nd, 2005, 1:15am
Thanks Rob,
One more question.The two equally sized load transitors at a particular Vctrl, will carry same amount of current which when added will give half the buffer current. So to get the gain of ur VCO stage the first step would be to charactreize your load as then you can tell the frequency variation right.Is it a right approach.
semitao
Re: ring vco
Reply #3 - Oct 15th, 2006, 8:14pm
keble wrote on Oct 30th, 2005, 12:45pm:
where:
Rob
Hi,Rob,
  Can you give some more detail formation about Maneatis's paper? Where can I find it?
thanks.
LowJitter
Re: ring vco
Reply #4 - Oct 18th, 2006, 5:01pm
semitao wrote on Oct 15th, 2006, 8:14pm:
Hi,Rob,
thanks.
John G. Maneatis , "Low-Jitter Process-Independent DLL and PLL Based on self-Bias Techniques," IEEE Journal of Solid-State Circuits, vol.31, No.11 November, 1996
