vborich
I am no expert on PSS but it's clear that you didn't set it up correctly. PSS is a strictly periodic, or one-tone, analysis, and the period is 1/200KHz in your case, which makes it impractical for PSS aplications. It appears that you set it up with 1GHz as the fundamental.
You should use QPSS or, if you have access to it, a harmonic balance simulator.
You could alternatively run this with envelope following analysis and 1 GHz as the clock freq. I don't know the names of Spectre envelope following parameters, but you want to make sure that the maximum envelope time step is no larger than 1/20 MHz and that you run it for at least 1/200 KHz.
Vuk
