vivkr
Hi Paul & David,
Thanks for the feedback and the links. I think it should provide useful reference material.
Regarding the suggestion of using a PRBS to drive a 3-state machine, I already thought of that but if you look carefully, you have 3 states with probabilities of 1/2, 1/4, 1/4. This would be undesirable. Perhaps, I need to insert a random scrambler in between before I map 2 bits from the PRBS to a 3-state machine. This ought to even out the probabilities a bit more.
I need to try out these suggestions first. Thanks again.
Vivek
