Hello Sheldon,
Thanks a lot for the reply.
Quote:The design will also be limited by the usual constraints, for example, aperature jitter. Twice as fast needs the aperature glitter needs to be twice as small.
1.For the case with conventional pipelined ADC operating at 200Msps and double-sampling ADC operating at 200Msps, the aperture jitter requirement is the same. I could not understand this statement completely.
2. I have gone through some papers on non-idealities of double-sampling technique and parallel pipelined ADC, but none of them really give an estimate what is the limitation on the resolution and speed of the ADC because of those non-idealities. Is behavioral modeling only way to determine these limitations.
3. "10b 150Msps with analog bandwidth of 200Mhz with a Imax of 120mA" is it feasible to achieve using double sampling technique in pipeline ADC. Does anyone have better architecture suggestions.
After lot of literature study I could not come to a conclusion on this. Any suggestions/references will be of great help to me.
Ramakrishna
