Oct 17th, 2026, 8:10pm
simulating DAC nonlinearity (Read 3518 times)
vivkr
Nov 08th, 2005, 7:14am
I am wondering how best to simulate the nonlinearity of my 12-bit DAC. Basically, I need to consider mismatch effects in order to see the INL/DNL, but if I do this with a Monte Carlo run, then it is practically impossible, since each single run itself takes several hours and generates a lot of data.
Is there an efficient way of simulating the nonlinearity of a DAC? Would it be sufficient if I just simulate the nonlinearity around the major carry transition?
Vivek
Visjnoe
Guest
Re: simulating DAC nonlinearity
Reply #1 - Nov 8th, 2005, 11:52am
a lot depends of course on your DAC architecture, but in general my suggestions are:
1. For the static non-linearity (INL/DNL), if you don't want to
   take the simulation penalty imposed by Monte-Carlo,
   I would resort to behavioral/macro-modeling. If you only
   simulate the worste case transition, you have to make
   sure it's really worst case (can you ever be sure...I'd   prefer
   a verification which checks all DAC input codes...)
2. For the dynamic non-lineariry: apply a sine wave near
   the Nyquist frequency at the DAC input.
Hope this helps a bit
Kind Regards
Peter
  IP Logged
