Jul 24th, 2024, 12:23pm
pseudo-random sequence generator (Read 3707 times)
vivkr
Nov 02nd, 2005, 8:10am
I am looking for a simple way to generate PRBS sequences. I should like to have one with a fairly long period (2^20 say), but the bigger problem is that I would
like to use this to get 3 states which are equally (or almost equally) likely, but the period in which these states occur is fairly long.
Typically, it is easy to get 2 such states out of a PRBS (any of the outputs) but trying to get 3 states out of it has me stumped.
I would appreciate any help. I am not much of a digital designer but if there are references describing design of such a block, then I think I can pick it up.
Vivek
Paul
Switzerland
Re: pseudo-random sequence generator
Reply #1 - Nov 2nd, 2005, 11:16am
Hi Vivek,
PRBS sequences are generated using linear feedback shift registers (LFSRs). You can find sample code here (doulos.com):
http://www.doulos.com/knowhow/vhdl_designers_guide/models/bist_circuits_part_one...
and here (generic implementation):
http://vnsnes.freeshell.org/lfsr/LFSR.v
In order to make sure each sequence only occurs once each 2^N-1, you must chose the taps correctly. More on this and an introduction to Galois field math are presented here:
http://www.newwaveinstruments.com/resources/articles/m_sequence_linear_feedback_...
The two implementations of LFSRs are shown in this reference, but you should be aware that the tap definition to obtain PRBS sequences is opposite.
I hope this answers your question.
Paul
jbdavid
Reply #2 - Nov 3rd, 2005, 9:03am
The first thing that occurs to me for a 3 level output, would be to alternate the "1" value between +1 and -1..  so every even 0-1 transition would go positive and the odd ones would go negative. you'd maintain the same direction until the next 0..
another idea.. use the state change of the prbs sequence to drive a 3 state counter/modulator.. this has the disadvantage of either a 1 to -1 or -1 to 1 transition on every third state change.
a third idea .. bring out 2 bits from the prbs sequence..
then assign two patterns to the same value.. ie
00 = 11 = 0 , 10 = -1 , 01 = +1
this should, in effect, be the differential of the PRBS pattern..
Hope this helps
jbdavid
vivkr
Reply #3 - Nov 4th, 2005, 4:33am
Hi Paul & David,
Thanks for the feedback and the links. I think it should provide useful reference material.
Regarding the suggestion of using a PRBS to drive a 3-state machine, I already thought of that but if you look carefully, you have 3 states with probabilities of
1/2, 1/4, 1/4. This would be undesirable. Perhaps, I need to insert a random scrambler in between before I map 2 bits from the PRBS to a 3-state machine. This ought to even out the probabilities a bit more.
I need to try out these suggestions first. Thanks again.
Vivek
