May 19th, 2024, 12:17am
Analog bus limitation, any work-around ? (Read 3681 times)
ekne
Yupp, I'm a viking
San Diego
Nov 04th, 2005, 8:55pm
Hi
Using AMS Designer and want to do:
   electrical amx;
   real V_amx_3;
   real V_amx_2;
initial begin
   #50;
    V_amx_3 = V(amx[3]);
    V_amx_2 = V(amx[2]);
etc.....
but get an ncelab error that this is not supported i.e.
analog bus in "digital domain".
So is there a way to work-around this ?
Not, talking about changing the schematic to not use an
analog bus i.e. define two separate signals.
Why isn't this supported, don't really see why it should
be a limitation at all.
(spice/digital busbit notations < vs [ ? perhaps ? but
 that shouldn't be a limitation)
Thanks //BEE
jbdavid
Re: Analog bus limitation, any work-around ?
Reply #1 - Nov 9th, 2005, 9:26am
I wrote up a great idea, thats NOT the answer to your problem..
Yes workaround is easy.. don't do the conversion in the logic domain.. do it in the analog block..
jbdavid
jbdavid
Reply #2 - Nov 9th, 2005, 9:31am
ie:
   electrical amx;
   real V_amx_3;
   real V_amx_2;
analog begin
   @(timer(50n)) begin
// this is a ONE time event, like initial block
// initial begin
//    #50;
etc.....
jbdavid
Reply #3 - Nov 15th, 2005, 11:12am
Hi BEE,
There's a PCR for this - 295207. It's an implementation limitation at the moment - I've asked for a status update on this PCR.
ekne
Yupp, I'm a viking
San Diego
Reply #4 - Nov 15th, 2005, 7:31pm
Thanks Mr Andrew
I thought I give this forum a try. Very interesting one.
Will keep on returning to it.  ::)
Thanks again.
 //BEE
