Apr 28th, 2024, 10:04am
Data export problem (Read 683 times)
KiYoung
Guest
Data export problem
Nov 08th, 2005, 4:28pm
I have problems with getting data in text file format
from the AMS simulation results.
Simvision does NOT have "print" option as in calculator.
I searched all over the pull-down menus and also manuals,
but couldn't find it.
Also, it seems DirectPlot of AMS menu does not work
for current. Even if I select a terminal, Simvision waveform
viewer displays nothing, although voltages are displayed well.
Am I supposed to set something up before simulation?
Lots of thanks in advance,
KiYoung
  IP Logged
KiYoung
Guest
Re: Data export problem
Reply #1 - Nov 8th, 2005, 5:20pm
Sorry, folks.
It was under File->Export....  in Simvison.
But, current probing is still not functional.
KiYoung
  IP Logged
