Hi Yawei,
Do you mean you're trying to convert 4.3.4 libraries to the newer 5.X format? If so, you need to use 4.4.6 or earlier (maybe IC50 as well, I can't remember when the library conversion utility was removed).
Or are you trying to go back the other way? I'm not really sure what you're trying to do here...
