May 18th, 2024, 3:22am
DFII->DM library conversion (Read 3486 times)
Nov 10th, 2005, 10:04pm
I need convert some DFII libraries to DM libraries. But there isn't convert DFII-DM libraries in the Conversion Tool Box. The shell reports command not found when I want to start stand alone tool using libcvt. Sad
Can you help me?
Yawei
Re: DFII->DM library conversion
Reply #1 - Nov 16th, 2005, 11:29pm
Hi Yawei,
Do you mean you're trying to convert 4.3.4 libraries to the newer 5.X format?
If so, you need to use 4.4.6 or earlier (maybe IC50 as well, I can't remember when the library conversion utility was removed).
Or are you trying to go back the other way? I'm not really sure what you're trying to do here...
jbdavid
Reply #2 - Aug 3rd, 2006, 4:01am
Assuming the DFII lib means NOT managed.. and the DM lib means Managed (by the low cost VersionSync)
mkdir /my/path/to/my_new_VSVAULT
vssetvault /my/path/to/my_new_VSVAULT /my/path/to/my_new_sandbox
gdmimport /old/path/to/someones/dfII/library/RefLib /my/path/to/my_new/sandbox
jbdavid
