May 17th, 2024, 1:53am
ring vco (Read 2305 times)
vijay
ring vco
Nov 14th, 2005, 5:26am
I have a symmetric load 4 stage ring vco for simulation.Initially I try to simulate it by giving constant bias volatages at the PMOS bias and NMOS bias voltages. I do a transient analysis for observing the oscillation.But instead the simulation shows the two voltages stuck up at high (3.814V and 3.125V) for a 0.6um process.
pmos bias volatge is 0.5V and NMOS as 2.5V.
Thanks in advance,
V
Sezi
I LoVe ICs!
Sweden
Re: ring vco
Reply #1 - Nov 23rd, 2005, 10:02am
The differential voltages, both of them stuck at high? Check your circuit maybe you have made some wrong connections..
Re: ring vco
Reply #2 - Nov 23rd, 2005, 6:26pm
Hi, Vijay,
I think that stuck is due to wrong bias. Do you bias the PMOS and NMOS using voltage source?
Please bias your ring VCO using a reference current, and generate the bias voltage for ring VCO using current mirror. Smiley
Best regards,
Yawei
