What are you trying to convert it to? Spectre's VCCS has min and max parameters that should deal with what you have.
I'm a little confused by the subckt, though: a G element is a VCCS (voltage-controlled current source), but it is sensing a current I(v1), which makes it look like it should be a current-controlled source. Is it a CCCS or a CCVS??
