Jul 16th, 2024, 10:09am
Read from a file (Read 4396 times)
Zorro
Read from a file
Nov 25th, 2005, 2:52am
Hello Everybody,
I have a .txt file (for example) containing information that I need to load into a module. Let's say I have a file like this:
0:5
1:32
2:40
9:17
etc
where the left side refers to the addresses of a memory(rom) and the right side refers to the information to be written to every address.
Is there a way to do that? Is there a way to read from an external file?  ???
I've seen some topics with information about how to write to a file. But, in this case, it's just in the other direction.
Thanks for your suggestions.
Re: Read from a file
Reply #1 - Nov 27th, 2005, 8:43am
Zorro
Reply #2 - Dec 1st, 2005, 12:46am
hello Andrew,
thanks for the link. I've tried the $table_model  function and it worked fine. I loaded a simple table describing the behavior of a resistor
# this is the file resistor.tbl file
# using r = 5 Ohms
#      V(a, b)      I(a, b)
     1      0.2
     2      0.4
// resistor_table.vams
module resistor_table (a, b );
     inout a, b;
     electrical a, b;
     analog begin
           I(a, b) <+ $table_model(V(a, b), "resistor.tbl", "L");
I would like to know if you or somebody has used the fscanf function (va or vams). It's the form:
$fscanf (multi_channel_descriptor , "format" { , storage_arg } )
The problem I have is that the multi_chanel_descriptor must have a value associated with a currently open file. If a use for example:
integer i;
i = $fopen("file.txt");
$fscanf (i, "format" { , storage_arg } )
the information in file.txt will be erased because of the $fopen but I need to open this file in read only mode.
Thanks for any suggestion.
Reply #3 - Dec 1st, 2005, 3:57am
I think (digital) Verilog supports mode arguments to $fopen, a la C:
$fopen("file.txt", "r");
and thus, many of the AMS simulators from the major EDA vendors support this, even though it is not in the AMS LRM.
Zorro
Reply #4 - Dec 1st, 2005, 4:39am
Thanks Geoffrey,
I've found something in internet (but in verilog-PLI) using something like:
i = $fopenr("file.txt");
and I thought that "r" comes from read only (I mean, open without editing). But in the LRM for verilogA/AMS I didn't find nothing about it.
I'm gonna try your suggestion: $fopen("file.txt", "r");
Douglas
