Aug 15th, 2024, 1:19am
mixer conversion gain different by pxf and pss? (Read 675 times)
dot13
Dec 01st, 2005, 3:28am
hi,
i simulate a single-in balance-out mixer using pxf according to the spectreRF user guide, and get a conversion gain -9dB, while when i use only pss,and plot the voltage gain, it's -15dB,  exactly -6dB discrepancy! what's the reason?
Re: mixer conversion gain different by pxf and pss
Reply #1 - Dec 1st, 2005, 5:08am
I suspect you have used a port at the input, and the input is completely unmatched? Perhaps you have a high input impedance with your mixer, and so pxf is giving you the gain from the internal source. Since there is an implicit gain of 2 from the voltage source, which would then be divided by 2 if the gain matched - but if driving a high impedance you'd get an extra gain factor of 2 with pxf. With pss you're measuring the voltage gain from net to net, so the mismatch doesn't matter any more.
If your mixer does in fact have high impedance input, use a voltage source as the input instead of a port.
Note, the above is a bit of a guess - without more info on the circuit, it's hard to be sure.
dot13
Reply #2 - Dec 1st, 2005, 8:05pm
You are quite right! That's the reason.
I also find some informations on the "spectreRF user guide".
thanks a lot
