Juddy
Hi all, I use vco+div2 as my LO generator. here is the simulation results, without div2(4GHz), -105@100k, -135@3M with div2(2GHz), -110@100k, -140@3M (just 5dbc/Hz improved) From the noise contribution, it can be seen that the devices of div2 contribute a lot(20%), especially the bias of div2. Also, my vco output peak-to-peak swing is around 1v(single end) without any load, but turn to 700mv with div2 as loading. I simulated the phase noise of the div2, and its PN from 100k to 10M is about -150dBc/Hz. so I think div2 itself should not contribute so much noise. Does anybody know what's wrong with this.
Thanks in advance.
