nus_lin
I found that the setup of transient analysis is tricky for the simulation of settling time. the settling time extracted is strongly dependent on the setup, say, for the default setup, the 0.1% settling time is 28ns, but if i manually set the maxstep to be 5ps, the settling time became 36.6ns, if i change other setup such as soving method, the value also change.
now my question is, which value is correct, which kind of setup has the best accuracy in terms of settling time extraction?
