jbdavid
This is probably a year late, but maybe it will help someone.. ( I was in severe time crunch then also, so not reading the forum) a config view is a "configuration" of some "design" view.. you already have to have specified the design you want to configure.. In cadence this will generally be a schematic, so you also need symbols for all the blocks, devices you are putting in your design.. Alternatitvely you can just create a verilogams netlist of the top level..
you can specify psf format for your analog outputs, then AWD can read them, but wavescan can read both analog and digital signals
