Ok, so when you say it will have that value for all time, it will also change with its value as well, hence the block that just changes the register?
Also, you were corect about the const functions. They are just functions which multiply the operand by a certain constant needed for my filter.
I redid the code, and got it to compile like this:
Code:module filter(clk,x,y);
input clk;
input [7:0] x;
output [7:0] y;
reg [15:0] stage1;
reg [15:0] stage2;
reg [7:0] y;
wire carry2;
wire carry3;
wire [15:0] a1;
wire [15:0] b1;
wire [15:0] b2;
wire [15:0] sum2;
wire [15:0] sum3;
initial
begin
stage1 = 16'b0;
stage2 = 16'b0;
y = 16'b0;
always @ ( posedge clk )
begin
mult_const_b1( y, b1 );
add16( stage2, b1, 0, sum3, carry3 );
mult_const_b2( y, b2 );
add16( stage1, b2, 0, sum2, carry2 );
mult_const_a1( x, a1 );
assign stage1 = a1;
assign stage2 = sum2;
assign y = sum3[15:8];
