Aug 14th, 2024, 5:22pm
Phase Frequency detector gain (Read 1995 times)
Tikka
Dec 05th, 2005, 1:10pm
This is related to a topic I put on the RF design section of this forum before I discovered this section.
http://www.designers-guide.org/Forum/?board=rfdesign;action=display;num=11337716...
I need to work out the gain for my model for the phase domain model of my Phase frequency detector. The actual circuit is of the flip flop type with one D-type triggered by the reference clock and another triggered by the divided VCO clock. The reset to both of them is the AND function of the two D-type output with a delay added for deadband compensation. When the UP output goes high the charge pump sources Icp and when Down goes high the charge pump sinks Icp. I think this is a fairly standard type of architecture. I believe my gain should be 2*Icp/2PI as there is a contribution during simulation for a frequency deviation and a similar contribution for a fixed phase offset and hence the reason for 2*Icp. Can anyone please confirm this to be true?
Andy
