Apr 28th, 2024, 1:22am
Simulation Setup for Varactor C-V and Q-freq curve (Read 13084 times)
cheraskid
Dec 06th, 2005, 12:34am
I'm trying to simulate the varactor C-V and its QvsFreq curves for different sizes of the AMOS varactor.
I've no problem on ADS since it has some of the readily available functions for extracting the cap value but when it comes to SpectreRF, I'm lost.
Does anyone know how to setup the simulation in SpectreRF?
BR
cheraskid ???
Re: Simulation Setup for Varactor C-V and Q-freq c
Reply #1 - Dec 8th, 2005, 3:07am
Hi.
You can do them using Ocean Script.
The following is examples. This is inductor case.
But it is easy also for capacitor case.
Read documents about details of Ocean.
awvSetOptionValue('dateStamp t)
awvSetOptionValue('displayGrids t)
awvSetOptionValue("cursorPrecision" 9)
awvSetOptionValue("displayAxesBy125" t)
pi = acos(-1.0)
date = getCurrentTime()
;base_dir = getWorkingDir()
base_dir = "~"
circuit_dir = "sim_ind"
sim_data = "schematic"
result_dir = strcat(base_dir, "/simulation/", circuit_dir, "/spectre/", sim_data)
openResults( strcat(result_dir, "/psf") )
selectResult("sp-sp")
y11 = yp(1 1)
y22 = yp(2 2)
Q1 = imag(1/y11)/real(1/y11)
Q2 = imag(1/y22)/real(1/y22)
L1 = imag(1/y11)/(2*pi*xval(y11))
L2 = imag(1/y22)/(2*pi*xval(y22))
fx = 3.0GHz
printf("Q1@%gGHz=%g\n", fx/1G, value(Q1, fx))
printf("Q2@%gGHz=%g\n", fx/1G, value(Q2, fx))
printf("L1@%gGHz=%g[nH]\n", fx/1G, value(L1, fx)/1n)
printf("L2@%gGHz=%g[nH]\n", fx/1G, value(L2, fx)/1n)
wid = newWindow()
addTitle("Quality Factor of Inductor")
bid = currentSubwindow(1)
addSubwindowTitle( sprintf(nil, "Q1=%g , Q2=%g at %gGHz", value(Q1, fx), value(Q2, fx), fx/1G ))
plot( Q1 ?expr '("Q1") )
plot( Q2 ?expr '("Q2") )
xLimit(list(1G, 10G))
awvSetXAxisLabel(wid "frequency [Hz]"  ?subwindow bid)
awvSetYAxisLabel(wid 1 "Quality Factor of Inductor" ?subwindow bid)
addSubwindow()
bid = currentSubwindow(2)
addSubwindowTitle( sprintf(nil, "L1=%g[nH] , L2=%g[nH] at %gGHz", value(L1, fx)/1n, value(L2, fx)/1n, fx/1G ))
plot( L1 ?expr '("L1") )
plot( L2 ?expr '("L2") )
;xLimit(list(68u, 77u))
awvSetYAxisLabel(wid 1 "Inductance [Henry]" ?subwindow bid)
final
Korea
Re: Simulation Setup for Varactor C-V and Q-freq curve
Reply #2 - Jul 28th, 2013, 11:13pm
Can anyone help me to simulate & calculate capacitance of Varactor in spectre? I want to plot C-V. I am a newbie in cadence simulator Embarrassed I just know very simple thing. I appreciate any comment.
Thank in advance.
« Last Edit: Jul 29th, 2013, 6:52am by final »
Reply #3 - Jul 29th, 2013, 12:38pm
Connect a voltage source to the capacitor with its AC magnitude set to 1. Perform an AC analysis where you sweep the DC voltage of the source over the desired range (you are sweeping voltage rather than the frequency). Set the AC analysis frequency to 1/2π. Plot the current.
I = j2πfCV
where f=1/2π and V=1, and so I = C.
