Jul 22nd, 2024, 5:33am
SNR in spectre wavescan calculator tool (Read 5770 times)
bunny
huh...analog
design..
Dec 07th, 2005, 4:49am
Hello all,
I have a doubt in using the SNR function in the spectre wavescan calculator. I am trying to
find the SNR of a 10bit ADC. I interfaced it with an ideal 10bit DAC (spectreHDL model).
I performed the FFT of reconstructed signal(a sine wave) from ideal DAC output. I followed all the rules
of coherent sampling.
Now I used the SNR function and performed the following operation
snr(fft(V(vo),2.6u,259u,128),27.3k,249.6k,27.3k,249.6k)
where my input freq: 27.3K
Fs= 499.2K (Fs/2= 249.6k)
I am performing 128-point fft
i.e.,
signal_from:27.3K
signal_to: 249.6K (Fs/2)
Noise_from: 27.3K
Noise_to: 249.6K
but it resulted in InfinitydB
Now I reduced the signal_to range from 249.6K to 245K i.e.,
snr(fft(V(vo),2.6u,259u,128),27.3k,245k,27.3k,249.6k)
it results in SNR= 80.768dB (I am not sure of this value as I was expecting SNR around 60dB for 10-bit ADC)
can anybody explain me if I am doing it right. I am not sure abt the frequency ranges I am using for SNR.
Even a small change in the frequency range is affecting my SNR values as they are jumping wildly
from one value to another.
One more doubt...the magnitude of the fundamental(27.3K in my case) in the fft plot is exactly half of the
maximum value of the reconstructed sinewave. I was expecting it to be Vm/root(2)(rms value). Why is it showing Vm/2?
thanq
Re: SNR in spectre wavescan calculator tool
Reply #1 - Dec 24th, 2005, 5:33am
Bunny,
  The signal window should include the signal and
not the noise. The signal window should be the center
frequency +/- resolution bandwidth for the Rectangular
window. For other FFT windowing functions this
recommendation will change. In this case, 27343.75
+/- 3906.25 Hz --> 23437.5 Hz - 31250 Hz.
  Next, it would be better to directly reconstruct the
analog signal in the calculator, fft( (1/Vfull_scale) *
V(msb)/2 + V(msb-1)/4 + V(msb-2)/8 + ..., from, to,
# points). Using a DAC can introduce new issues.
Performing the calculation once is some work.
However, you can save it as an output or as a
calculator memory and re-use it later.
 Some other comments:
1) Using the snr function you are really calculating the
   SINAD of the ADC. For non-sampled circuits, the
   distortion is at integer multiples of the fundamental
   frequency. Usually, the distortion is outside the
   frequencies of interest. In this case, you are including
   the noise and distortion in the frequency of interest.
2) The snr and thd functions are not intended for
    sampled circuits. For normal circuits, the distortion
    occurs at integer multiples of the fundamental
    frequency. For sampled circuits, the distortion occurs
    at the same frequencies, however, the sampling
    process folds the distortion back into the baseband.
bunny
huh...analog
design..
Reply #2 - Dec 25th, 2005, 4:54am
sheldon,
Thanks for the reply. This is working perfectly. One more question. I have a Sigma delta modulator for which I need to measure the performance metrics. How do I measure the SNR and other parameters of a sigma delta modulator? Is there any way to reconstruct the modulated output signal with spectre wavescan calculator tool?
Thanq
Reply #3 - Dec 25th, 2005, 6:18am
Bunny,
  You shouldn't need to reconstruct the analog, just
perform the FFT directly on the output pulse train.
bunny
huh...analog
design..
Reply #4 - Jan 4th, 2006, 2:49am
Sheldon,
I have tried to plot the fft of the output pulse train(+1 and -1) of a second order SDM. The input to my SDM is a sinewave with amplitude=1v and input frequency fin=5.1K.  In the FFT output, the amplitude of the fundamental spike (at fin=5.1K) is shown to be in microvolts (2.7uV). The clock frequency is (Fs=819.2K). I was expecting the amplitude of the fundamental spike to be around 1V. Can u tell me where I went wrong? I am attaching the FFT output for clarity.
bunny
