NOIMOD=2 is from BSIM3, and uses with NOIA, NOIB, NOIC.
I find Andrew's post a little misleading:
Quote:Parameters noia,noib,noic etc would also suffice to cause flicker noise.
If NOIMOD=1 or 4 (or 5), then NOIA, NOIB, NOIC will have no effect at all. If NOIMOD=2 or 3
(or 6), then NOIA, NOIB, NOIC are used, and they have non-zero default values, so you may or may
not find the value in the model card (though the defaults are unlikely to be correct for your process).
(NOIMOD=5 and 6 were added in BSIM3 version 3.3 and make a slight change to the thermal noise model
relative to NOIMOD=1 and 3, respectively.)
