Aug 31st, 2024, 6:28pm
saturation (Read 3509 times)
safwatonline
saturation
Dec 08th, 2005, 4:37am
hello,
this is my first post here , i am new to analog design in general , i am using orcad 9 , in my bias point simulation i found that the parameter Lin0/sat1 equal =-1
does this mean that this mos is in saturation also why is the -ve sign ,
another question is that if i have vds>vgs-vth , but vds<vdsat
and lin0/sat1 equal -1 is this in sat.
Re: saturation
Reply #1 - Dec 15th, 2005, 8:39am
I've never used orcad9, so I'm not familiar with lin0/sat1; can you look it up in the documentation?
As to vdsat: I think vdsat from channel pinch-off is related to vgs-vth, and you can also have saturation due to velocity saturation.  However, I'd expect velocity saturation to lower vdsat, so I'm not sure how you get vds>vgs-vth and vds<vdsat.
Croaker
Re: saturation
Reply #2 - Feb 8th, 2006, 3:41pm
For short-channel devices, velocity saturation makes Vds,sat < Vgs - Vth.  Most people refer to Vgs - Vth as Vov (overdrive).
If you are biased such that Vov is very small, I think it's possible that Vds > Vov but it is still not larger than Vds,sat.
The key point here is that Vds,sat != Vgs - Vth.
