Aug 15th, 2024, 7:55am
relationship between sideband and  harmonics (Read 3016 times)
jacky lee
Guest
Dec 08th, 2005, 11:01pm
In cadence Manual, in pss+pac analysis of mixer,usually  number of harmonics in pss analysis is 0 or 1, but index of sideband in follow pac  is -25 ,-21
is it correct? because the transfer functin associated with the relative index k results from the small-signal being convolved with the kth harmonic of the steady-state solution.,so the -25,-21
sideband in pac should be results from the small-signal
being convolved with the -25th   harmonic of the steady-state solution . but number of harmonics in pss is 1. so ONLY 0 1th harmonic is generated . is result of simulation correct? ???
  IP Logged
Jess Chen
California Bay Area
Re: relationship between sideband and  harmonics
Reply #1 - Dec 12th, 2005, 7:56am
The pss/pac example you referened is used in another part of the SpectreRF User's Guide but with a longer explanation of where the sideband indices come from. Search for mixer_ip3. The mixer_ip3 example is part of the Top Down Behavioral rfLib.
However, to reproduce the published results, the latest code requires that you set the pss highorder option to "yes" and also select conservative options. There is a pcr to make this example work once again with default options.
-Jess
jacky lee
Guest
Reply #2 - Dec 12th, 2005, 5:37pm
thanks for replying Smiley
  IP Logged
