jacky lee
Guest
In cadence Manual, in pss+pac analysis of mixer,usually number of harmonics in pss analysis is 0 or 1, but index of sideband in follow pac is -25 ,-21 is it correct? because the transfer functin associated with the relative index k results from the small-signal being convolved with the kth harmonic of the steady-state solution.,so the -25,-21 sideband in pac should be results from the small-signal being convolved with the -25th harmonic of the steady-state solution . but number of harmonics in pss is 1. so ONLY 0 1th harmonic is generated . is result of simulation correct? ???
