May 1st, 2024, 11:28am
instantiation of modules (Read 5011 times)
sylak
Silicon valley
Dec 14th, 2005, 1:59pm
hi all,
1. I get the 'segmentation violation' error when I instantiate this nand module
nand_gate #(.vlogic_high(1.2),.vlogic_low(0),.vtrans(0.54),.tdel(10p),.trise(20p),.tfall(2
0p)) Nand(a1,b1, out);
vlogic_high,vlogic_low ..etc are parameters declared in the module.
and I want to connect the 'in1' 'in2' and 'out' of the nand module to 'a1' 'b1' and 'out'
I am not sure as what the error signifies!
2. when instantiation , do the modules have to declared in "`include " I looked at various examples in this website, they were not declared. Does this assume the modules to be in the same directory.
I have tried the simualtion by including the module path using the `include ' /path/nand.va' ... doesnt seem to make a difference as far as the error message is concerned but Would like to know if this is necessary.
Thanks in advance!
S
Re: instantiation of modules
Reply #1 - Dec 15th, 2005, 8:59am
I include .va models in Spectre netlists with
ahdl_include "/path/nand.va"
It appears you have a Verilog netlist, so the `include should be correct there.
Does spectre read Verilog netlists?  How do you specify the analyses?
sylak
Silicon valley
Reply #2 - Dec 16th, 2005, 1:38pm
Geoffry,
Thank you for replying!
I dont use spectre to run simulations. I use hsim which supports veriloga modules. so I write the testbench in spice and use '.hsimveriloga' statement to define the path to the veriloga module.
I have the nand gate written in veriloga and it seems to work fine when I run the simulations. I seem to have trouble only when I write a veriloga code to instantiate a module.
I have no idea as what the error means. dont know which directions to look to correct the error- the simulator, the code or the testbench. ?. Just posted it here to see if any one had this kind of problem before.
S
Reply #3 - Dec 21st, 2005, 7:58am
A "segmentation violation" is usually an indication of a bug in the executable: part of the program is trying to access memory that is not associated with the program, probably a pointer that wasn't updated.  So, I might suggest sending a test case off to the HSIM support folks.
