Jul 16th, 2024, 7:46am
Verilog-a vs. Verilog-ams (Read 5557 times)
mrbrown
Denmark
Dec 16th, 2005, 8:34am
What is the difference between Verilog-a and Verilog-ams?
Thanks.
Re: Verilog-a vs. Verilog-ams
Reply #1 - Dec 21st, 2005, 7:59am
Verilog-A is a subset of Verilog-AMS.  Verilog-AMS has a language reference manual (LRM) available from http://www.eda.org/verilog-ams, and one of the appendices specifies what subsets of the LRM are part of Verilog-A.
The idea is that Verilog-A should consist only of things that can be simulated in an analog (spice-like) simulator.  AMS includes digital things and generally requires a second (digital) simulator running with the analog simulator.
Kenneth Brun Nielsen
Guest
Reply #2 - Dec 21st, 2005, 8:01am
OK. That makes sense. Thanks!
/Kenneth
  IP Logged
