Paul
As the PCI-Express standard is not openly available, it may be useful if you provide more information on the jitter spec.
I presume you are talking about sinusoidal jitter in the jitter tolerance specification, right? If so, in most serial link standards (GbE, FC, etc), there is a jitter tolerance mask defined for sinusoidal jitter, which I thought would be the same for PCI-Express.
In your post, ist it this jitter tolerance mask you are talking about?
Paul
