Jul 22nd, 2024, 11:31am
determine absolute max rating value for analog chi (Read 1570 times)
chu
Dec 27th, 2005, 10:13pm
how to determine the absolute max rating value for analog chip ?? by measuring on physical chip ???
is it partly from the spec for the packaging ? what about other criteria ?
thx in advance.
Re: determine absolute max rating value for analog
Reply #1 - Jan 3rd, 2006, 5:52am
Absolute max of what? Voltage? Temperature? Current?
Usually, the datasheet for the part lists max values, though I think the manufacturer guarantees the part will not be destroyed (or will work properly) if you don't exceed the absolute max, whereas a particular sample might tolerate even more.
