Aug 19th, 2024, 8:24pm
How to model BJT breakdown? (Read 7942 times)
steven
Dec 31st, 2005, 5:40pm
I wonder how to model BJT BV_cbo or BV_ceo, where Ib or Ic would be zero? Or maybe the breakdown can only be observed from measurement?
Re: How to model BJT breakdown?
Reply #1 - Jan 2nd, 2006, 4:37am
It's possible to model breakdown in simulation. Mextram 504, which includes weak avalanche, allows one to capture the reversal of base current (and hence to find the point where Ib=0).  Probably other models do, also; Hicum also includes equations for B-E Zener breakdown.  Neither of these models captures snapback, nor "strong" avalanche.
steven
Reply #2 - Jan 2nd, 2006, 9:48pm
I looked up Mextram model a bit for Philips. This is a c-library file and dedicated to specific simulators. So ususally how do you apply a given *.c model file when the specified simulators are not available. I vaguely recalled that general simulator like HSpice can inport a *.c model file. Is it correct?
Reply #3 - Jan 3rd, 2006, 5:11am
You should have a look at the Verilog-A description from TU Delft: http://hitec.ewi.tudelft.nl/mug/
HSpice has a Verilog-A option that will allow it to run Verilog-A models.  (The C code from Philips can't be used in HSpice.)
steven
Reply #4 - Jan 3rd, 2006, 9:57am
Thanks Geoffery, that helps. It is good to know HSpice can run Verilog-A mode. Will look it up.
steven
Reply #5 - Jan 4th, 2006, 9:29am
Hello Geoffery,
Can you point a quick link or example syntax on how to use the HSpice option for Verilog-A? I couldn't find that on my HSpice manual. Thanks for your comments.
Reply #6 - Jan 5th, 2006, 8:42am
.options post=ascii
.hdl "diode2.va"
X1 1 0 diode2 rs=10
V1 1 0 1
.dc v1 -1 1 0.01
.end
The instance letter is always X.  Also, you have to have the right HSpice -- I think there's a "basic" HSpice that doesn't include the Verilog-A option.
steven
Reply #7 - Jan 5th, 2006, 8:19pm
I see why my HSpice doesn't have this function. It is a basic one. Anyhow, I will keep a mind note on this.
Thanks Geoffrey,
(Sorry I spelled your name wrong in my previous post. There should be a function can view what the previous posts contents were)
