vivkr
Hi sven,
It has been a while since I worked on ring oscillators, but it seems to me that for a ring oscillator, the plot you show is still remarkably good. Normally, the V-F curve of a normal oscillator is seldom very linear. For most cases, this is probably good enough.
Why do you need it to be so linear anyway? Is there a special application or are you trying to use your oscillator with some special loop configuration?
Regards Vivek
