Jul 21st, 2024, 5:21pm
cmos fully differential amp voltage scaling (Read 3704 times)
steven
Dec 26th, 2005, 8:42am
I obtained a cmos fully differential folded cascode circuit. The circuit was designed on 2um process. Now the same will be used on 0.18um for a prototype. I wonder if there is a better way to scale the bias voltages in the circuit (Vdd and Vss are still the same as the original circuit).
irfan
Re: cmos fully differential amp voltage scaling
Reply #1 - Jan 8th, 2006, 3:14pm
In my opinion it is a new design.  Sure the architecture is the same, but the 0.18-um process is about at least six or seven generations ahead of the 2-um process.  You will have to watch out for the following:
(1) Break down voltages for the 0.18-um process as the supplies from the 2-um design haven't changed
(2) Sure, Vth & Lmin are small now, but watch out for the voltage dependent Rds & gm as both Vth & L_effective have voltage dependency now.
(3) Lower Vth, will also lower your maximum output swing
(4) More leakage current in stand-by mode
That's all I can think of now.  The last time I desgined a folded cascode in 0.18-um was back in 2001.  If you need more help, I can dig up my old notes.  :)
steven
Reply #2 - Jan 8th, 2006, 7:33pm
Hello Irfan,
What you pointed out is correct. Maybe your notes have something not covered. Anyway, the notes should be helpful.
Steven
Reply #3 - Jan 10th, 2006, 3:40am
Steven,
I guess that the original design (2um) is operater at 5V supply that may destroy a 0.18um circuit eventually.
yawei
steven
Reply #4 - Jan 10th, 2006, 10:29am
Hello Yawei,
This is a good point. So some level shifting may come as an option? I would see how Irfan's design approach.
Steven
zhonghan
china
Reply #5 - Jan 15th, 2006, 8:55pm
it is easier to adjust biases for the circiuts than to reduce the power voltage.
I am  a new comer of the community ,very glad to discuss problems with you.
