irfan
In my opinion it is a new design. Sure the architecture is the same, but the 0.18-um process is about at least six or seven generations ahead of the 2-um process. You will have to watch out for the following:
(1) Break down voltages for the 0.18-um process as the supplies from the 2-um design haven't changed (2) Sure, Vth & Lmin are small now, but watch out for the voltage dependent Rds & gm as both Vth & L_effective have voltage dependency now. (3) Lower Vth, will also lower your maximum output swing (4) More leakage current in stand-by mode
That's all I can think of now. The last time I desgined a folded cascode in 0.18-um was back in 2001. If you need more help, I can dig up my old notes. :)
