Jul 16th, 2024, 9:29am
syntax error `include (Read 3750 times)
billtsang
Jan 07th, 2006, 9:34am
I got syntax error when i " `include "constants.h" ". Can anyone point out the reason.
Error found by spectre during AHDL read-in.
   "th.def", line 10: "`<<--? include "constants.h""
   "th.def", line 10: Error: syntax error
   "th.def", line 14: "electrical <<--? Pin, Nin, Pout, Nout ;"
   "th.def", line 14: Error: invalid module terminal type (*undef*) for
       Pout.
       Nout.
   "th.def", line 14: Error: invalid module terminal type (*undef*) for Pin.
   "th.def", line 14: Error: invalid module terminal type (*undef*) for Nin.
   "th.def", line 14: Error: syntax error
   Maximum allowable errors exceeded.  Exiting SpectreHDL compilation....
// Periodic Track & Hold
// Works with SpectreRF (has no hidden state)
// Almost ideal ...
//    Has buffered input and output (infinite input Z, zero out Z)
//    Exhibits no offset or distortion errors
//    Only nonideality is finite aperture time and very small amount of droop
`include "disciplines.h"
module th (Pout, Nout, Pin, Nin) (period, delay, aperture, tc)
electrical Pin, Nin, Pout, Nout ;
input Pin, Nin;
output Pout, Nout;
parameter real period=16n from (0:inf);
parameter real delay=0 from (0:inf);
parameter real aperture=period/2 from (0:period/2);
parameter real tc=aperture/10 from (0:aperture);
integer n;
real tstart, tstop;
electrical hold;
   analog begin
// Determine the point where the aperture begins;
     n = ($abstime - delay + aperture) / period + 0.5;
     tstart = n*period + delay - aperture;
     @(timer(tstart));
// Determine the time where the aperture ends;
     n = ($abstime - delay) / period + 0.0;
     tstop = n*period + delay;
     @(timer(tstop));
// Implement switch with effective series resistence of 1 Ohm
     if (($abstime > tstop - aperture) && ($abstime <= tstop))
         I(hold) <+ V(hold) - V(Pin, Nin);
     else
         I(hold) <+ 1.0e-12 * V(hold);
// Implement capacitor with an effective capacitance of tc
     I(hold) <+ tc * ddt(V(hold));
// Buffer output
     V(Pout, Nout) <+ V(hold);
// Control time step tightly during aperture and loosely otherwise
     if (($abstime >= tstop - aperture) && ($abstime < tstop)) begin
         $bound_step(tc);
     end else begin
         $bound_step(period/5);
Re: syntax error `include
Reply #1 - Jan 9th, 2006, 11:38am
A few points:
1. Don't give the filename the suffix ".def". This tells the ahdl_include in spectre that the file is spectreHDL, not
   Verilog-A. Your code is (mostly) VerilogA - the bits which aren't is probably a mistake...
2. You list the parameter names on the module line. That's spectreHDL syntax, and shouldn't be there for Verilog-A.
   So the module line should just be:
module th (Pout, Nout, Pin, Nin);
3. Put the electrical definition after the port directions. It will work in spectre (with a warning these days), but in other tools they may be more strict and require the port direction before the discipline. For example:
input Pin, Nin;
output Pout, Nout;
4. delay is a reserved word. I had to change the parameter to something else (I used "del").
Reply #2 - Jan 9th, 2006, 11:39am
I meant to say that after all that, it compiles in both spectre and AMS Designer. I didn't check that the code works  8-)
jbdavid
Reply #3 - Jan 10th, 2006, 4:41am
In verilog - the parameters (if included in the module declaration header ) go BEFORE the pin declarations..
I've never used this feaure of Verilog2001 ..
jbd
jbdavid
