Jul 16th, 2024, 12:31pm
Digitally Controlled Analog Events (Read 3242 times)
irfan
Jan 08th, 2006, 11:43am
Hi!  I am a mixed-signal IC designer with strong emphasis on analog design.  About three weeks ago, I seriously started using the Verilog-AMS to model my existing designs.  In sharp contrast to what I had originally thought about modeling in AMS, I am now having way too much fun doing this.   Smiley
While modeling in purely analog form is no problem, I am having some issues when converting analog models to mixed-mode models, in particular, when using digital events to control analog behavior.  As I don't have a reference book handy at home, I will appreciate anyone's help with the following:
(1) Is there a way to make things level sensitive rather using either @(posedge X) or @(negedge X)?  I am trying to make the following more general as the control signals may change or may stay constant during the sim:
// Unit resistance vs. SG settings
 @(posedge (SG00 | SG01))
     Runit = 4.6k;
 @(posedge SG10)
     Runit = 2.1k;
 @(posedge SG11)
     Runit = 1.0k;
(2) Can one use the “case” statement for a digital bus in order to control analog? If yes, then what is the correct syntax?  For example, I want S[3:0] to have 4 different cases and I am trying to get away from doing the following:
// Rint values vs. Range settings --> 2-to-4 digital decoder output
 @(posedge S[0])
     Rint = 116*Runit;
 @(posedge S[1])
     Rint = 87*Runit;
 @(posedge S[2])
     Rint = 69*Runit;
 @(posedge S[3])
     Rint = 57*Runit;
Thanks in advance for your help.
Irfan
Re: Digitally Controlled Analog Events
Reply #1 - Jan 9th, 2006, 11:24am
Here's a little example, using a case statement. Note I'm also using always @(S) which means that the code will get invoked any time S changes (positive or negative), and then a case within. You could of course use if within.
`include "disciplines.vams"
module myres (a,b,S);
inout a,b;
input[1:0] S;
electrical a,b;
logic[1:0] S;
real rval;
always @(S)
  case (S)
  2'b00: rval=1.0K;
  2'b01: rval=2.0K;
  2'b10: rval=3.0K;
  2'b11: rval=4.0K;
  endcase
analog begin
  V(a,b)<+I(a,b)*rval;
This would then be compiled using:
ncvlog -ams myres.vams
My testbench is as follows:
module testit;
reg[1:0] S;
electrical agnd;
ground agnd;
electrical n1;
initial begin
    S=2'b00;
    #50 S=2'b01;
    #50 S=2'b10;
    #50 S=2'b11;
    #50 $finish;
isource #(.dc(-1.0m)) I1(n1,agnd);
myres R1(n1,agnd,S);
And to compile this:
ncvlog -ams testit.vams
With an analog control file (very simple) of:
tran tran stop=400n
I can then elaborate and simulate with:
ncelab testit
ncsim -gui -analogcontrol testit.scs testit
Attached is a png file (out of wavescan) showing the resulting waveforms (I'm plotting the voltage, as the resistor value changes). Note the model is pretty lousy, because it doesn't change the resistor value smoothly - it has an instantaneous switch (which is not a good thing), but this is just to illustrate the principle  ;D
irfan
Reply #2 - Jan 9th, 2006, 4:49pm
Thanks a lot Andrew!  This is way more than what I had expected from this forum!   Grin
