May 19th, 2024, 6:28pm
MOS small signal output resistance model (Read 4575 times)
steven
Jan 14th, 2006, 9:07am
Given a MOS device at saturation, how to estimate the small signal output resistance rout?  For example, if Id doubles, rout will decrease anti-proportionally (almost) according to approximation rout=Va/Id, with Va is related to geometry parameters and Vds. However, if taking a MOS device model for a  simulation, the Gds hardly changes if Id changes. So it seems rout is not simply the relation was just outlined. Note that the simulation ensures the device is under saturation.
Thanks.
Re: MOS small signal output resistance model
Reply #1 - Jan 17th, 2006, 6:41am
With some processes, 0.18u and below, the pocket or halo implant causes real trouble when trying to fit the output conductance curves.  I've seen humps in the measured data.  In that case, I don't think you'll find an easy approximation.
steven
Reply #2 - Jan 20th, 2006, 3:41pm
Hi Geoffrey,
For circuit design purpose, I guess Rout is then assumed to be constant with respect to Id. In achieving enough voltage gain, we sometimes need Rout large. But it seems Rout is not well approximated by the pointed relation. Well, longer device can increase Rout.
Thanks for the information,
Steven
pbs681
Reply #3 - Feb 17th, 2006, 6:09pm
I have 1 question. Is there any relationship between rout and rds as we know that rout is the resistance looking at the output node when transistor is on, while rds is parasitic resistor. Sorry if I asked basic question. I just graduated and still new. Please help me.
