Jul 16th, 2024, 9:51am
3 derivatives at 3G??? (Read 1989 times)
jefkat
Jan 16th, 2006, 1:09am
Hi everyone..
                I have a vco operating at 3G. I wanted d/dt, d2/dt,d3/dt, (first , second and third)
drivative of the output waveform. I am using Verilog A. In the trasient analysis some
nodes go to very high voltages for the obvious reasons. so simulator stops.
                  These high voltages are due to the fact that 1. frequency of waveform is high (2)
in the begining I use some step voltages to start the oscillator.
                   Is there anyway to tell the transient to not take those initial things into account,.
Any help!
           Thanx for your time ...
              jefkat
Re: 3 derivatives at 3G???
Reply #1 - Jan 17th, 2006, 6:47am
Can you use something other than a step?  Maybe a PWL?
Can you set the blow-up quantity such that the simulator doesn't stop when the "voltages" get so large?
As I understand it, they're just derivatives, not actual circuit voltages.
You could also look into doctoring your Verilog-A so that it doesn't output anything until 10ns.
analog begin
 if ($abstime > 10n) output = 1;
 else output = 0;
 V(deriv) = ddt(V(in) * output);
