Apr 26th, 2024, 10:50pm
How to add L and W of resistor in CDL netlist (Read 6267 times)
jaylin79
Jan 17th, 2006, 9:58pm
Hi guys,
Can somebody tell me how to let CDL netlist automatically add the size L and W of resistor? I can only know add the model and M of transistors.
Best Regards
Jay
Jay
bernd
Munich/Germany
Re: How to add L and W of resistor in CDL netlist
Reply #1 - Jan 18th, 2006, 2:01am
Assumed you use Cadence DFII for CDL netlisting
(which tolls are used is always a helpful information)!?
You have to modify your CDF (Component Description Format)
of the resistor for CDL netlisting, I guess.
CIW -> Tools -> CDF -> Edit
!!! CDF Type must be Base
- Simulation Information
Edit there the auCdl Section to something like
cdfId->simInfo->auCdl = '( nil
       netlistProcedure  ansCdlCompPrim
       instParameters    (M L W)
       componentName     yourComponentName
       termOrder         (PLUS MINUS)
       propMapping       (nil M m L l W w)
       namePrefix        "R"
       modelName         "yourModelName"
or just use the SKILL command
cdfDump(t_libName t_fileName
   [?cellName t_cellName]
   [?level s_level]
   [?edit b_edit]
to get the CDF information as text file, edit it and load it back with
load( t_fileName )
For more information about  CDL netlisting refer to the Cadence online  Docs
'Design Data Translator's Reference', Chapter 3 'Translating CDL Files'
Bernd
Just another lonesome cad guy
jaylin79
Reply #2 - Jan 18th, 2006, 5:55pm
bernd,
Thanks a lot, I can use your 1st way, yet I don't know how to find the SKILL file, where is it?
Best Regards
Jay
Jay
bernd
Munich/Germany
Reply #3 - Jan 19th, 2006, 1:26am
I do not know exactly what you mean with SKILL file,
maybe you misunderstood me.
cdfDump is not a SKILL file, it's only a SKILL command which dumps out the
CDF as a text file. OK, it's a SKILL format if you mean that, that
can be modified in a editor, rather than using the GUI to modify the CDF.
If you didn't find this file it's on you. What have you used for
the t_fileName  argument. If you use just a file name without path
details it should be put in the directory form which you have started
the DFII.
Or try it with t_fileName == "./myCdf.il", I mean with a leading
./ before the file name.
Or maybe it's landed somewhere in your SKILL path, getSkillPath( )
returns the path.
Bernd
