Paul
I don't have the Calibre rules manual at hand right now, but I would expect you to find a command defining a) filtering properties (i.e. the minimum capacitor size to appear in the netlist, the ones below being filtered out) b) a rule for merging parallel capacitors. Unless you specify the second, all extracted capacitors will appear individually in the netlist.
Paul
